Re: Farmall Super C - sheared gear teeth on hydraulic dri...
Posted by State of Jefferson on December 28, 2010 at 09:19:07 from (63.170.86.177):
In Reply to: Farmall Super C - sheared gear teeth on hydraulic drive gear posted by brumik on December 28, 2010 at 08:48:21:
Someone with more C experience than myself will chime in on this, but I had to replace the Cam gear(drives the hyd pump) on my SMTA this summer. It is kindof a big job, but not overly technical. Just a matter of un-bolting and bolting stuff. Whole front end of the tractor needs to come apart.
Shop around for the part. I ended up Getting mine from Draper Tractor in Washington.
Good luck.
Ben
