Re: date code on engine
Posted by El Toro on December 28, 2010 at 09:35:53 from (108.3.200.96):
In Reply to: date code on engine posted by gabor on December 28, 2010 at 09:23:23:
You may have the engine block used on the Super C's. Look for this casting number 354898R1 as the sleeve diameter measure 3.4375" at the seal and the overall length is 7.060" used in this block. Measure the old sleeves and see if they have the same measurements. Hal
PS: You can install an overbore kit in this block without any machining to the block using 3.250" pistons & sleeves.
