Re: Farmall Super C - sheared gear teeth on hydraulic dri...
Posted by gene bender on December 28, 2010 at 09:36:08 from (67.55.227.196):
In Reply to: Farmall Super C - sheared gear teeth on hydraulic drive gear posted by brumik on December 28, 2010 at 08:48:21:
You need to remove radiator and then the steering sector so the front pulley can be removed then you can take off the front cover. Use a bearing seperator to remove the front pulley along with the pthree jaw puller so you dont break the pulley. If you dont have a way to support the tractor and have tools maybe you better not do it yourself or get someone who can help that has some experience.
