Re: pto leaking oil
Posted by Zachary Hoyt on December 28, 2010 at 09:57:22 from (184.8.238.212):
In Reply to: pto leaking oil posted by Farmallb on December 28, 2010 at 09:48:14:
If it is leaking right around the shaft you need to undo the two bolts there and the cap yanks right off. Then you drive out the old seals, usually a two in one kind of deal, and go buy yourself two new ones and put them on. I can't recall the number for the new seals now but you can get the number off the old one and get it cross referenced. I like to park the tractor pointing downhill so I don't have to worry about oil escaping. Once you get the new seals on wrap a sheet of paper around the PTO stub to keep from nicking the the new seals and slide the cap back on. Bolt it down and you're good to go. Should be an easy half hour job at most. If the leak is where your whole PTO unit joins the rear end case you can just use some RTV in there to make a gasket.
Zach
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
