Re: Farmall Super C - sheared gear teeth on hydraulic dri...
Posted by Andrew Z on December 28, 2010 at 13:45:54 from (64.252.112.28):
In Reply to: Farmall Super C - sheared gear teeth on hydraulic drive gear posted by brumik on December 28, 2010 at 08:48:21:
Had the same problem this past summer. Not a bad job just a pain the rear. When you remove the front pulley you will need ample heat in order to get it to move. Also a little when putting the pulley back on.
Andrew
