Re: Farmall Super C - sheared gear teeth on hydraulic dri...
Posted by Marv on December 28, 2010 at 14:13:46 from (75.105.64.52):
In Reply to: Farmall Super C - sheared gear teeth on hydraulic drive gear posted by brumik on December 28, 2010 at 08:48:21:
I bought a SC recently with the same problem. The previous owner did not keep hydraulic oil in the hyd, system and the pump froze up... same as you described. It sheared the teeth off the hyd.pump, idle gear and cam shaft gear. I think the hyd. pump froze up because it was not getting lubericated with hyd. oil. As mentioned before, the entire front of the engine will have to be removed. The chance of getting the crank pulley off and on without breaking it is about 50%. Good luck.
