Re: Farmall Super C - sheared gear teeth on hydraulic drive
Posted by Janicholson on December 28, 2010 at 14:42:35 from (67.72.98.57):
In Reply to: Re: Farmall Super C - sheared gear teeth on hydraulic drive posted by brumik on December 28, 2010 at 14:17:38:
The roll on its side did do it. It took contaminated material that was held down by gravity and put it back into circulation. Either in the gears, or the hydraulic pump. When it is apart, make sure everything is flushed clean, and clean the screen in the reservoir as well. One chip of crud will take out gears when they have no place for the chip to go. In a pump the gears also jamb, causing stripped teeth, or sheared Keys. Good luck. Sand the inside of the Pulley when it is off just enough to allow a medium press fit for install.
Do not heat it too much warmer than 200 degrees when reinstalling, or it will melt your new front seal. Jim
