Re: Color of my Hydraulc Oil? and a few other questions.
Posted by Janicholson on December 28, 2010 at 15:44:25 from (67.72.98.57):
In Reply to: Color of my Hydraulc Oil? and a few other questions. posted by Fullers Farmalls on December 28, 2010 at 15:31:57:
You have water contamination in the oil. It must be heated to drive it out (safely and with a double boiler system outside is best, no flame). Replacing the oil will also work.
The answer to the last part of the question is determined by how it is set up now. If there are hoses running to the top of each lift cylinder, it will need probably 10 gallons. If not about 6 gallons will do it. Some use Hytran hydraulic oil. If it were mine, I would probably use a slightly heavier hydraulic oil than it is. Maybe a mix of Hytran and the heavier oil. The original oil was specified as non-detergent 30 wt in summer and 20 wt in winter. Best of luck, Jim
