I am with Jim on this one. Most likely a head gasket. The bigger question is, do you have coolant in the crankcase. both liquids in the wrong place is NOT a good sign. coolant in the oil is either a failed head gasket, sleeve "O" ring, or cracked block/head. Mostly the first.
Oil in the cooland is usually a head gasket, however, it can also be a crack in the block or head.
If you take the head off, if it is the gasket, you will see where it is leaking.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
