rich , i would stongly suggest changing your filter also , its on the right side under the plate with six bolts, theres a metal screen and a paper filter , the plate is spring loaded so watch your feet when it comes off. in this cold weather any moisture will collect in the paper filter and freeze leaving you with no hyd or steering, ive had a couple 460s for years now and learned in minnesota weather to run a couple bottles of isopropyle in the hyd oil. good luck
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
