Re: H Starter Drive?
Posted by Owen Aaland on December 28, 2010 at 22:30:35 from (198.70.47.181):
In Reply to: H Starter Drive? posted by WOpp on December 28, 2010 at 21:12:59:
Here is a picture of the two different styles. The original style is on top mounted on the armature.
third party image
The original style uses the spring to absorb the shock load when the drive engages the flywheel ring gear. Failures usually include bent or broken spring, bolts coming loose and rubbing on the case, or the gear wedging in the ring gear locking the starter and engine.
The newer style has uses rubber to better absorb the shock load. They also tend to not stick in the ring gear and lock the starter like the original style can do.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
