Re: Using an H with a three point hitch and a loader
Posted by mkirsch on December 29, 2010 at 05:38:38 from (64.80.108.56):
In Reply to: Using an H with a three point hitch and a loader posted by holmesw on December 28, 2010 at 07:13:57:
I suspect your plan is to go to Home Depot and pick up some inexpensive water valves for this purpose...
Hydraulic pressure, even on a low-pressure tractor like an H, is 10 times normal household water pressure.
Water valves are designed and rated for household water pressure, maybe 80PSI. Your H's hydraulic system will produce 800PSI.
You do the math...
