Re: date code on engine
Posted by CNKS on December 29, 2010 at 06:26:35 from (216.144.104.128):
In Reply to: date code on engine posted by gabor on December 28, 2010 at 09:23:23:
I assume you mean 310000 and 350000. If so you need sleeves for a block with the part number 354898 with an R suffix followed by some number. 354898 R- is cast in the block on the right side. To double check measure the bore diameter at the groove for the sleeve (NOT in the groove, outside of it)-should be 3 7/16 or 3.4375, to make sure someone has not bored it further. It takes 3.25 inch diameter pistons. Also make sure the gasket kit is for an engine without a water pump.
