You probably won't get it all out. These systems are self priming, so I would bleed down the cylinders into a bucket. Remove the lower mount and use a jack to full travel the lift cylinders to their limit to discharge all the oil you can (you could rinse them, i would not). Then drain the fluid from the bottom of the Liftall. Refill with new oil (the oil should have about the same actual viscosity as 20 wt engine oil) then lift an lower refilling as needed to replenish the same amount that came out. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
