Re: H Trouble
Posted by Zachary Hoyt on December 29, 2010 at 10:28:49 from (184.8.238.212):
In Reply to: H Trouble posted by ARF on December 29, 2010 at 10:19:49:
Are you completely sure the problem is in the head itself? I would think the head gasket and maybe the block would also be potential sources of leaks. I don't know anything about remanufactured heads, but I do know that if you keep running it with the antifreeze it may end up costing a lot more to fix if you need to do lower end work in the engine.
Zach
