Posted by gene bender on December 29, 2010 at 12:16:18 from (67.55.227.196):
In Reply to: Farmall a governer posted by redblood on December 29, 2010 at 07:50:31:
520 PTO speed is not far off and will work on your mower justfine. The correct way to set carb linkage is With engine off remove the pin in the clevis goin to the carb. Now open throttle wide open. Now ADJUST CLEVIS SO PIN GOES IN HOLDING CARB OPEN. You miteneed to remove the linkage so you can get the clevis to turn easy but thats the way to set linkage. How much play does the input shaft hae on the gov housing you dont want any slop for good operation. Were the holes worn for the spring and all springs free and working. You get the linkage set and youre speed should fall in line. Still 520 is awful close.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
