Re: f 20 all fuel starting from scratch
Posted by oldiron29 on December 29, 2010 at 14:09:45 from (69.112.87.249):
In Reply to: f 20 all fuel starting from scratch posted by tugboattim on December 29, 2010 at 11:50:56:
Tug, If you have an IH F-4 mag there is a cap to remove and see if you points are opening.
The cap has a tab that conects to the rod to steering coloum. Full down on cap is kill off,
Up a little is retard spark and full up is run position. If you get no spark in run position eather point are bad or not set right. Coil in mag is bad or condensor. Most I have had needed the coil replaced. I order and replace my own not hard to do. Oldiron29
