Posted by D Slater on December 29, 2010 at 16:33:37 from (184.15.27.36):
In Reply to: P Suffix posted by Bouncer on December 29, 2010 at 15:47:20:
Maybe a B that didn't get a good stamp. If so there should be a X1B following the engine serial # with a original engine. B = came equiped for operation around 5000 ft. altitude with higher compression pistons.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
