Re: H Trouble
Posted by teddy52food on December 29, 2010 at 17:16:09 from (68.169.216.43):
In Reply to: H Trouble posted by ARF on December 29, 2010 at 10:19:49:
Pull the pan & see where it is coming from. There is a soft plug on the front of the block that may be leaking.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
