1941 MD info needed
Posted by Mark Parker on December 29, 2010 at 19:53:00 from (24.20.166.89):
I just bought a 1941 Farmall MD and need some information on it. Serial number is 26978. Does anyone know serial number of the first production MD tractor? What are some serial number of other produce before this one. Were does this one fall in line around the 100th built or 500th built? How do you check the oil level in injector pump I see a 1/8 drain plugs on side of pump body at bottom and one on bottom of govenor body at end are these both drains? Looks alot different than the later pump. IT has 6" longer rear axles with Two notches cut in them on each side 2" from end of axle. what are these for??
