Re: 1256 weight w/coleman front
Posted by kennell on December 30, 2010 at 05:23:15 from (142.68.108.74):
In Reply to: 1256 weight w/coleman front posted by larryanderson on December 30, 2010 at 03:47:51:
1256's are around 10500 lbs. You need to add weight for a cab and duals. I'm guessing another 3000 lbs for the cab and duals.Your in the 14000 lbs range. hope this helps. Kent
