Okay, heres the deal: A light wimpy charger used briefly isnt gonna help much in starting, although it can help if used long enough to bring the battery up to a good state of charge and warmed up and then you start the tractor. However one of those big honkin 100 or 200 amp boost chargers may be able to spin a relatively small tractor starter motor for a while if it cranks easy n its not too cold.
I dont normally recomend using a 12 volt charger on a 6 volt battery for a rookie but I have done it with care for short times if on a low charge setting and watched so she dont overcharge and do NOT be making or removing conenctions near the battery top where explosive gasses are present........ No matter if a 6 or 12 volt charger once the battery really gets cooking and/or youre using the starter there are explosive gasses near the battery so avoid connection or removal sparks there by attaching the charger (last connection) to a good clean case/frame ground AWAY from the battery. The batterys hot ungrounded voltage is present/available places like the starter switch (where big battery cable attaches) so you avoid sparks near the battery.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
