Re: Can I start my Farmall 200 - Six volt with a 12V charger
Posted by oldtanker on December 30, 2010 at 06:15:12 from (66.228.255.223):
In Reply to: Can I start my Farmall 200 - Six volt with a 12V charger? posted by JSullivan on December 29, 2010 at 17:19:22:
12 volt will not hurt the starter as long as you don't run it too long. 12 volt to the ignition system can fry the points and burn up the coil unless it has the resistor in line to reduce the voltage to 6 volt.
1 make sure the battery is fully charge.
2 make sure all the electrical connections are clean and tight. That includes the starter mounting.
3 if the starter still runs to slow make sure you have winter weight oil and if that is good it may be time to rebuild the starter.
Rick
