Re: Can I start my Farmall 200 - Six volt with a 12V char...
Posted by teddy52food on December 30, 2010 at 07:27:02 from (68.169.216.43):
In Reply to: Can I start my Farmall 200 - Six volt with a 12V charger? posted by JSullivan on December 29, 2010 at 17:19:22:
How cold is cold? If you keep it in shape it will start below zero with a 6 volt battery. At -25 to -30 you can still start them with the crank & leave the full battery voltage to fire the coil. You may need new heavy battery cables & bolt it to a good ground to the starter bolt & not to the battery box. Is the battery good? Fix what is not right first.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
