Re: Coil 6v or 12v??
Posted by jdemaris on December 30, 2010 at 10:21:53 from (67.142.130.14):
In Reply to: Coil 6v or 12v?? posted by Mr. Mayor on December 30, 2010 at 08:26:57:
Just adding to John T's comments with a few specs.
Coils need to make good spark at 9 volts in a 12 volt system, not 12 volts. The vast majority (90 %) of coils used in OEM 12 volt systems are what many here call "6 volt."
Ignition coils I have checked:
1992 Subaru 12 volt breakerless: 2.4 ohms primary
NAPA IC-12 Echlin 2.1 ohms primary, 8.9 ohms secondary made for no external resistor
NAPA IC-14 Echlin 3.25 ohms primary resistance No external resistor used.
NAPA MPEIC14SB same as IC-14, just cheap Chinese. $18.69
NAPA IC-27 Echlin 2.2 ohms primary, 6.38 ohms secondary - no external resistor.
A500 12 volt 2.6 ohms primary, 9.8 ohms secondary
No external resistor.
Deere 6 volt (as used on 420,430,1010, 1020, 350 crawler, etc. 1.6 ohms prim, 7.12 secondary
Hot Spark brand - HS06HEC - HEI, CDI and electronic ignition systems - .6 Ohms primary resistance. 11.6 K ohms secondary.
Mallory 29219, 12 volt coil - primary 1.4 ohms, secondary 9.8K ohms. 58K volts. Use with external resistor.
Mallory 29217 12 volt breaker-point coil, primary 1.4 ohms, secondary 9.8K ohsm, 58K. Use with external resistor.
Lucas coils:
DLB101............standard 12 volt coil (primary resistance 3 ohms). No external resistor.
DLB102...........standard 12 volt coil for use with 1.6 ohm ballast resistor (coil primary resistance is 1.5 ohms). Also used on 6 volt systems.
DLB105...........high performance 12 volt coil (primary resistance 3 ohms). Use external resistor.
DLB110...........high performance 12 volt coil for use with 1.6 ohm ballast resistor (primary resistance 1.5 ohms). Also with 6 volt system.
