Re: 1066 crankshaft balancer question
Posted by Owen Aaland on December 30, 2010 at 19:12:44 from (207.13.114.161):
In Reply to: 1066 crankshaft balancer question posted by PoppinJohn720 on December 30, 2010 at 19:02:59:
The thicker one is probably a viscus fluid type while the original on the tractor was a rubber cushion style.
I would use the new one from CIH.
There were things upgraded from the first production models. the woodruff key was made longer with steps to keep the key from sliding out of place while installing the pulley. If it comes out of place it will crack the new damper pulley. There was a thin sealing washer added between the pulley and the oil pump to keep oil from leaking between the crankshaft and pulley. There was a plate added to the front to keep dirt from being blown back into the seal by the fan.
