300U Pressure Plate Adjustment
Posted by Tommy Adams on December 30, 2010 at 19:26:10 from (98.80.38.130):
Just split my 300U to fix an oil leak and about to hang the pressure plate, thought I might best check the adjustment on the press plt, well, one finger is 1/8th" proud of the other two. Measuring from the front face to top of the finger is 2&7/8", the other two are 2&3/4". I have a IT book so I think I measured it right, the book said 2&7/32". Big difference. I didn't see any markings on the pressure plt as to make or anything. I got the tractor like it was so I figured the clutch was gummed up anyhow. It would engage w/o grinding if you held it in about 30 sec or so. Got a new clutch plate, the old pressure plate looked good, actually the old clutch had almost no wear on the lining, just gummed up.
If anyone has dealt with these before I could use some ideas.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
