Re: cub won't start
Posted by El Toro on December 31, 2010 at 07:22:39 from (108.3.200.96):
In Reply to: cub won't start posted by jeep 258goat on December 30, 2010 at 16:03:12:
Hold your hand over the throat of the carburetor while a helper makes an attempt to start the engine to see if there's much suction. Very little suction means your intake manifold vacuum is low which is needed to suck that fuel into the engine. Check your manifold and carburetor to make sure they're not leaking. Pull the sparkplugs and pour some engine oil on top of the pistons then crank over the engine a few times and replace the plugs then see if the engine will start. Hal
