Re: Push rod question
Posted by Janicholson on December 31, 2010 at 08:30:47 from (67.72.98.45):
In Reply to: Push rod question posted by Tom Fleming on December 30, 2010 at 15:13:00:
Use a wooden block on the end grain and tap with a plastic hammer such that high spots are removed.
Roll them on a flat surface. They bend from stuck valves, or hard things in the combustion chamber like metal or ice. They can be easily made usable. If they are bent enough to cause surface fracturing or stress marks, they are toast. I have used pushrods in car engines (When they were my own and I had no money), that were welded back together after snapping in two. They were subjected to radically more running stress than your engine will ever encounter. Jim
