You have to remove the wheel, spacer, and bolt-on bearing retainer. But that is only the beginning because the inner bearing will also have to be replaced. I include the inner bearing because it is now junk. That requires reaching inside the PTO opening and separating the bolt and bull gear from the axle inner end. The axle should come out easily. You are lucky the inner bearing didn't disintegrate and trash the axle housing.
You are likely to have problems with the splined wheel. It may have to be pressed off the axle in a large press.
I'd do both sides as long as you are replacing both wheels.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
