Re: Farmall Super C three point
Posted by Lmack on December 31, 2010 at 11:02:24 from (72.145.202.12):
In Reply to: Farmall Super C three point posted by Matt from PA on December 30, 2010 at 16:22:30:
If the top link bolts to the belt pulley delete plate, it is a bad set up. The belt pulley frame was not intended for that stress load and could crack your rear housing. My uncle had a setup that bolted to the axles as you said but the top link attached to a tube encasing the rock shaft over the top of the belt pulley housing. He was well pleased with it, but he never had a real Ford type 3-point.
