Tune the engine so that it will start. 6-volt is fine if the engine is tuned up and I do not like the 12 volt systems I have used. A properly tuned motor shoud start under any conditions even using 6-volts. As others have said, every tractor has a different combination so you need to learn how much choke and when. The 200 my father had required one turn of the engine under choke then no choke to start then maybe a flash choke if it started to stumble when cold. The 200 I have now requires choke to start then it will run fine with no choke. We only had 12 volt units to jump the battery for SC's, 200, SA, and 240 and never had a problem. Still use caution. Quit if it does not start right away and properly charge the battery.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
