I had the same problem on my H, only with a stock H carb. The fuel flow looked good but I had nothing to compare it to, so like a novice I rebuilt the carb. Tested and found same problem (but I have experience rebuilding the carb now!). I took a flashlight and looked in the tank and found a bunch of stuff in the inlet line inside of the tank. I also found an old gas can cap in there too, siting on top of the inlet. I used mechanic wire wired on the end of a wooden dowel and pushed the crud through (I filled up the glass sediment bowl 3/4 of the way full!) and then cleaned the glass bowl. Then I refueled and tested-- OK! Runs better than it ever did since I owned it. Hope this helps.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
