100 1st and 2nd gear?
Posted by oldiron29 on December 31, 2010 at 14:45:28 from (69.112.87.249):
Have a 100 that will not go into 1st and 2nd gear. I have pulled the cover and realign the fork and it will work a fue time than jumps out again. Should I try to bend the forks in, build up with weld or just replace them? Don't know if I can get them new. what is best fix?
thanks oldiron29
