Re: Can I start my Farmall 200 - Six volt with a 12V char...
Posted by wfd2 on December 31, 2010 at 14:49:24 from (75.197.48.252):
In Reply to: Can I start my Farmall 200 - Six volt with a 12V charger? posted by JSullivan on December 29, 2010 at 17:19:22:
I found that a 6v automatic charger will turn off before the 6v battery is fully charged so it will turn over the tractor. In cold weather, I use a 6v manual charger and simply charge for 20 minutes or so before going out and starting my old H. Also, I've found like the others, you have to find the trick to an easy start and all tractors are different. Mine wants full choke twice then no choke. Once it starts, pop the choke a couple of times within 10 secs or so until engine idles properly.
