For what it's worth, when I recored my F-20, I used 5/6" copper heavy wall tubing and soldered it in. You have to clean the the line and tank REALLY well before you start.
works fine, and doesn't leak.
I did have to use the acetylene welding tip to get enough heat though. you need to be real careful, and heat the tubing......too much concentrated heat is no good for the cast. I tinned it before I put it in, then heated the brake like, and pulled the solder in. I did the tank side first, then turned it over and did the rad side last, to let the solder work down and around.
It would be interesting to use JB Weld for this job. I have had excellent success with JB weld for repairing the oil cups on the air cleaner and similar sheet steel parts.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
