Re: Coil 6v or 12v??
Posted by greyfoxxca on December 31, 2010 at 16:03:21 from (137.186.159.24):
In Reply to: Re: Coil 6v or 12v?? posted by Mr. Mayor on December 30, 2010 at 13:23:42:
M Mayer
2 ohms does not sound quite right.
Did you check your meter by touching the ends and checking to see that it zeros ? if it does not just take away the error from the reading.
I would expect to see 1.1 to 1.5 ohms (with resistor or six volts)
or 2.4 to 2.9 ohms (no resistor or 12 volt)
2ohms seems in between the norms.
cheers
George
