Re: farmall m engine serial number
Posted by D Slater on December 31, 2010 at 16:23:50 from (184.15.27.36):
In Reply to: farmall m engine serial number posted by mainamana on December 31, 2010 at 15:35:52:
Look for international harvester serial # records at the wisconsin historical society. If you can find the right ones you can find the year and month engine was put in the tractor. Or post the engine # and I will look at a chart I made up to tell you.
