Re: Farmall 460 Power Steering Question
Posted by pete 23 on December 31, 2010 at 16:39:36 from (173.87.15.134):
In Reply to: Farmall 460 Power Steering Question posted by John Athey on December 31, 2010 at 07:04:26:
It most likely is a problem in the steering valve mounted right under input shaft at front bolster. Not unusual for them to break a washer or nut come loose off end of the link inside valve. Could be inside bolster, several possibilities in there like failed needle bearing, broken piston rings etc.
