Re: Grandpa's 52 H. What's needed?
Posted by sflem849 on December 31, 2010 at 17:56:37 from (69.197.84.192):
In Reply to: Grandpa's 52 H. What's needed? posted by Ron-MO on December 31, 2010 at 17:26:01:
Yepper, count the cells. It has 4 and each is good for 2 volts. "All" wet cell batteries can be figured out using this method.
That isn't a friction throttle. That is the POS sawtooth and your gpa put that rope on there bc when the notches wear out the stupid throttle falls out of its notch and flys back down to an idle. You can rebuild that plate, buy a new one, or switch to a friction throttle to overcome this problem. IIRC OEM has the replacement for around $75??? Knowing OEM it is twice as much as last year...
Doesn't look like too much stuff is wrong with it. I wouldn't go buying stuff until I pressure wash it really well and use it A LOT. You won't know what is wrong until you use it.
To the others, can't you strip the red paint off the grill emblem and paint the black back on it or does it look bad?
