Re: SA will not start
Posted by Daniel on July 06, 2000 at 18:07:28 from (205.188.197.48):
In Reply to: SA will not start posted by RalphVA on July 06, 2000 at 11:04:06:
My Super A had a similar no start problem with gas leaking from the carb. There was trash in the carb. causing the needle to stay open and flooding the engine before it could fire. Pulg a plug right after you try to crank it and see if you smell gas on it. It might be wet. I had to take the carb. apart and clean it. Good luck, Daniel.
Post A Followup
: Re: Re: SA will not start
