Re: Farmall 100 oil pan
Posted by Jg20601 on December 31, 2010 at 21:20:13 from (63.28.88.34):
In Reply to: Farmall 100 oil pan posted by John Hayes on December 31, 2010 at 20:33:27:
What type of problem?
Another question to anyone... any tips on what to do when you have an oil pump off? Pontiac had us putting wheel bearing grease in the pump for quicker pickup of the oil.
One time on my 140 I had to drip oil down the passage to fill the pump.. my dad had started to change the oil - when I went to use it I saw the drain plug was missing.
