Re: Farmall A 3 or 4 pole light switch
Posted by ScottyHOMEy on December 31, 2010 at 23:02:37 from (64.222.247.178):
In Reply to: Farmall A 3 or 4 pole light switch posted by Hayrake25 on December 31, 2010 at 20:44:45:
With the relay the 4 position switch would be your choice. The relay doesn't regulate the charge. The 3-position switch is strictly a light switch, off, dim and bright, intended ofr use with a regulator that will determine your charge rate. The two lower positions on the 4-position switch manually regulate the charge rate. Low is the only low charge rate. Hi is charge with no lites. The switch keeps the high charge rate on any time the lights are on in either the dim or bright positions. In all but the low charge position, the current runs directly to ground through the body of the switch. In Low it runs through a resistor before going to ground.
