Re: Farmall A 3 or 4 pole light switch
Posted by RTR on December 31, 2010 at 23:16:48 from (74.240.94.67):
In Reply to: Farmall A 3 or 4 pole light switch posted by Jeff Z. on December 31, 2010 at 20:44:45:
4 position (EARLY STYLE with Resistor Strip) is used. The positions are as follows: (L)ow - (H)igh - (D)im - (B)right
The 1st two positions are for the generator charging as it does not have a voltage regulator and the switch acts as one.
The 3rd and 4th positions are for the lights and are self explanitory. They automatically run in the High Charge position.
Make sure the resistor strip on the switch is in good condition, and that a proper fuse is installed. I use a 30 amp glass fuse either in a fuse holder, or on the back of the switch depending if it has a place for one.
