Re: Farmall A 3 or 4 pole light switch
Posted by Haas on January 01, 2011 at 06:13:05 from (75.204.163.2):
In Reply to: Farmall A 3 or 4 pole light switch posted by Hayrake25 on December 31, 2010 at 20:44:45:
If you are not concerned about being exactly correct, you will get much better battery life if you will replace the cutout relay with a voltage regulator. You can get one that mounts on the generator like the cutout and looks the same to the casual observer. In that case, you can use either the 3 or 4 position switch. With the regulator, the first two positions on the 4 position switch will just be off. It takes some rewiring to install the regulator, but it's not that difficult and over the long haul you will save the cost of the regulator by better battery life.
