The heavy press fit sleeeves were not used until the 706 were mid way in production so your 560 would be the light press unless new or different block has been installled. I normally fit the loose press blocks with a .002 oversize sleeve to get a nice press fit. Not extreemly tight but I push them in with a hydraulic installation tool. Will require cyl honing with rigid hone not glaze buster types. The head gasket does not seal on sleeve flange on the heavy press fit sleeve as it does with light press. Sleeve height is critical on the loose press style for gasket sealing and might possibly require shims for correction.Height is also critical on heavy press as they require special tool to install as you do not seat the flange of sleeve all way into block or you may crack sleeves.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
