Re: farmall h brake band
Posted by rustyfarmall on January 01, 2011 at 10:48:40 from (209.152.78.140):
In Reply to: farmall h brake band posted by CNKS on January 01, 2011 at 10:29:47:
I've cleaned up oil soaked brake bands using solvent and wet/dry sandpaper. I think also that liberal amounts of aerosol carb cleaner and maybe a wire bristled brush should work. You might also try immersing the band in a oan or bucket of disel fuel and let it soak for a day or two, and then follow up with the carb cleaner.
