Once you get her running, drain out 1 qt of oil from the pan. Then add 1 quart of diesel fuel Let her idle for about 10 minutes . Then drain her dry, change the filter and add new oil according to your climate. I'd also crack the rear tranny plug and see if water drains out. Drain any water and top off. Drain flush and refill radiator with new 50-50 antifreeze. Pull the fuel line off the carb, check that screen for clean. Remove the sedimate bowl and clean it. Open the sediment bowl valve and drain some fuel into a glass jar. What does it look like? If it's varnished, drain the fuel and replace with fresh. Check the air in the tires. Check the brakes Go for a ride. Send us a shot of you AND Gramps on it.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
