Re: Steering on Super MTA
Posted by CHATTY CATHY on July 06, 2000 at 20:37:51 from (216.240.74.15):
In Reply to: Steering on Super MTA posted by Chatty Cathy on July 05, 2000 at 10:59:39:
Thanks guys for the info. The part where the threads are stripped is right next to the bearing. It is a spindle about an inch in diameter. The threads are good at the front edge it is at the back edge where they are ruined. He put a washer on to scoot it out and that helped some. But if he puts another washer on then the kotter key hole will be covered up. were not sure what else to try. Does anyone know where to find a new or used spindle and how much they are. It's really not that bad but you know how guys are .Thanks again Phil and Les. Cathy
Post A Followup
: Re: Re: Steering on Super MTA
