You are going to remove the gov housing again as the dots arent correct if you placed the single dot on the gear between the two on the cam gear. The SINGLE on the cam gets lined to the Single on the gov gear you are way out of time the valves arent even close to make it run. When the dots are lined up correct not only is the gear that runs the mag in time the camshaft itself is way out of time. You need a good lite and clean up the cam gear good to find the single dot. Remove the plugs so you can turn the engine over with fan or crank its going to be fun but you can do it. ifn ya needs some help you can call 319-430-3907
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
